Clutch adjustment 92 883
I have a 1992 883. I need to adjust the clutch and need to verify if this is correct. Loosen cable adjustment ( how much? ) take off clutch cover, loosen lock nut, turn adjustment screw in till i feel resistanceback out half turn and lock down? Bike in gear or out? Can i open cover without having gear oil spill out? Also what is the correct play in primary chain 1/8 to 1/4?
Thanks
Thanks
RE: Clutch adjustment 92 883
I have not adjusted a clutch since they had them stupid ball bearings that needed to be preened in to the mechanism. BUT , I do believe the bikeshould be upright , someone holding on to the forks to check oil level ...
ORIGINAL: glennt7
Thanks
Thanks
HDF Tech
217
09-07-2023 09:07 AM
TheBanditColorado
EVO
18
04-09-2014 11:37 PM
Motorbulldog
03-24-2013 01:29 AM
