How to set the clock?
Old 05-26-2007, 09:29 AM
4dtough's Avatar
4dtough
4dtough is offline
Default How to set the clock?
Can't seem to locate my owners manual. Does anyone know how to set the clock on an 07 deluxe? Thanks
Old 05-26-2007, 10:00 AM
1of2's Avatar
1of2
1of2 is offline
"Moderator"
Default RE: How to set the clock?
The Deluxe has a clock?
Old 05-26-2007, 10:06 AM
copterdoctor64's Avatar
copterdoctor64
copterdoctor64 is offline
[ul][*]Turn Ignition to ACC or IGNITION.[*]Press and hold the function switch on side for 5 seconds or until 12 HR begins to flash.[*]Press and release function switch once to advance to a blinking 24 HR. Each time you press switch, it will change between 12 HR and 24 HR clock. Once you have it set on the desired time, press and hold function switch for 5 seconds. The display should change to the time display with the hours blinking.[*]Press and release function switch repeatedly to advance the hours. When correct hour is displayed, press and hold function switch for 5 seconds. The display should change to the minutes blinking.[*]Press and release function switch repeatedly to advance the minutes. When correct time is displayed, press and hold function switch for 5 seconds. The minutes display will stop blinking and your clock will be set.[/ul]
Old 05-26-2007, 10:26 AM
Heritage07's Avatar
Heritage07
Heritage07 is offline
ORIGINAL: 1of2
All 07's have a built in clock
Old 05-26-2007, 09:12 PM
vertigo14's Avatar
vertigo14
vertigo14 is offline
heheh ahhaha yep they have a clock
Old 05-28-2007, 12:26 AM
Jim Dawson's Avatar
Jim Dawson
Jim Dawson is offline
The '07s have a clock unless you replace the speedometer with the $500 combo tach/speedo, then you lose the clock. How dumb is that? [:@]
Old 05-27-2011, 11:46 AM
mstrRob's Avatar
mstrRob
mstrRob is offline
Stage IV
Default ??
Will this work on an FXDB 09 street bob?
johnanderson (05-08-2020)
Old 05-27-2011, 03:23 PM
mstrRob's Avatar
mstrRob
mstrRob is offline
Stage IV
Default arm
It sure did work
Old 04-14-2013, 07:45 PM
schlacker's Avatar
schlacker
schlacker is offline
Amazing, I checked my manual & the instructions for my combo & neither one tells me how to set clock.
Thanks for posting!
Old 04-14-2013, 10:22 PM
jam436's Avatar
jam436
jam436 is offline
Thanks for posting!
You sure?
From the catalog (pg. 627)...:
"..Combination Speedometer/Tachometer
Maintain the clean view over the handlebar. This unique
Combination Speedometer/Tachometer allows you to monitor
engine speed without adding additional handlebarmounted
gauges. The unit mounts in the stock dash opening
and is a direct plug-in installation. The backlit gauges include
a large LCD (liquid crystal display) information screen that
displays odometer/tripmeter data, miles-to-empty readings,
an easy-to-read segmented fuel display, a gear position indicator
and clock..."
Quick Reply: How to set the clock?
