Brake Light not working
Old 05-24-2007, 03:17 PM
95Heritage's Avatar
95Heritage
95Heritage is offline
Default Brake Light not working
I notice on my bike yesterday that the rear brake light don't come on when i hit my foot brake (rear brake) but works when I hit the front brake. I'm not sure if there is a switch i need to replace or what. I really haven't had time to look but i figure i would post this up to see if anybody else has had this problem.
Old 05-24-2007, 03:22 PM
sleepneagle's Avatar
sleepneagle
sleepneagle is offline
Default RE: Brake Light not working
rear brake pressure switch is gone. check the wires first, make sure they are connected. otherwise replace the switch.
Old 05-24-2007, 04:36 PM
95Heritage's Avatar
95Heritage
Thanks for the help. I'm going to try to look at it maybe tonight or it will be this weekend.
Old 05-24-2007, 06:43 PM
EVOrider's Avatar
EVOrider
EVOrider is offline
If you have a three way switch in there...that sounds like the name of it. Anyways, when you step on the brakes, it allows your turnsignals to act as brake lights as well.
It that switch malfunctions.....you have no brake lights at all.
Old 05-27-2007, 09:37 AM
thelawdoc's Avatar
thelawdoc
thelawdoc is offline
And I would check those connections for voltage drop in addition to continuity -a chore that many might neglect. I think it is always better to at least be able to let the techie know that you checked continuity and voltage drop already so that they can then go right to the more complicated stuff. Otherwise you simply pay someone to do the simple stuff you could have done -and they sure do charge!
Old 05-27-2007, 09:46 AM
jimmyz's Avatar
jimmyz
jimmyz is offline
usually the brake light switch on the MC is shot. Had to replace the switch on the sporty. Back in 99 the switch was only 6 or 8 bucks. JimmyZ
redman53
Electrical/Lighting/Alarm
04-10-2015 06:17 PM
Half-Fast Deuce
09-23-2012 07:56 AM
Rock Chalk
06-30-2012 04:49 PM
mpaquette
06-16-2012 08:58 PM
frenchbiker
10-26-2011 05:25 PM
Quick Reply: Brake Light not working
