Rear brake light not working
Old 05-02-2007, 01:06 AM
psycocavr's Avatar
psycocavr
psycocavr is offline
Stage I
Default Rear brake light not working
My 2000 FXDL rear brake light is not comming on.
The regular light works, the turn signals (side lights) work, the bulb is good (tested it with a 12v source).
The fuses are good.
I get power on a red/yellow wire in the block going into the rear tail light unit but no power on the brake light lead going to the bulb
unit.
What should I look for now? Is there some wireing I can access or test int he tail light unit?
**Update: I have traced wiring fromt he connectors under the seat, through a module and back to the rear tail light 'circuit board'
I have 11.5 volts at the correct connector but I still get no light. Is there some special amperage I need to see there?
Thanks,
PsycoCavr
2000 FXDL
Old 05-02-2007, 02:24 AM
ss377's Avatar
ss377
ss377 is offline
Default RE: Rear brake light not working
I do not have a manual covering your bike. I would check the brake light switch on the hand brake and foot brake and trace and test back to the light assembly. Mytail light assembly is coming off connector 7B of main harness.
Good luck.
Jason1977
04-03-2023 04:43 PM
Damien Bessent
09-20-2022 03:36 PM
trozenhorse
07-12-2012 10:40 PM
spdmtlrcng
04-01-2012 10:34 PM
roccitybiker
07-09-2011 11:06 AM
Quick Reply: Rear brake light not working
