kick stand rubber stop
Old 04-24-2007, 07:26 PM
woodhaven glide's Avatar
woodhaven glide
woodhaven glide is offline
Default kick stand rubber stop
I have a 07 flhx, the damn rubber stop on the kick stand keeps falling off, anyone else had this problem and if so have you found a fix for it?
[IMG]local://upfiles/27627/5FC6AD3432D44336A074AC3E004DAD2C.jpg[/IMG]
Old 04-24-2007, 07:33 PM
Sleeps In Trees's Avatar
Sleeps In Trees
Sleeps In Trees is offline
Default RE: kick stand rubber stop
Sand down the 'post' that the stop sits on w/rough sandpaper then thoroughly cleanoff all grit/dust. Nowglue the rubberstop on w/3M weatherstrip adhesive. Let it sit overnite.
VicW.
bdjhog's Avatar
bdjhog
bdjhog is offline
I have a 2006 and just noticed that after my weekend of riding I no longer have that rubber stop either. I guess when I replace it I'll try some sort of glue to help keep it on.
Old 04-24-2007, 08:05 PM
Johnny Law's Avatar
Johnny Law
Johnny Law is offline
ORIGINAL: Sleeps In Trees
VicW.
This is what I did. Problem solved.
JL
Old 04-24-2007, 08:09 PM
woodhaven glide
thanks guys I will try that now.
Old 04-24-2007, 08:10 PM
BiggestDawg's Avatar
BiggestDawg
BiggestDawg is offline
Advanced HDF Member
There's supposed to be a rubber stop?!? Now I know why mine rattles against the bike all the time Going to have to look into this[:-]
Old 04-24-2007, 08:20 PM
Doc's Avatar
Doc
Doc is offline
I better look. I don't remember one....
Old 04-24-2007, 08:30 PM
EvilDave's Avatar
EvilDave
EvilDave is offline
Make sure you use the YELLOW 3M weatherstrip adhesive, holds much better than the black.
Old 04-24-2007, 09:16 PM
stich's Avatar
stich
stich is offline
I can't say for sure what it looks like but a friend of mine said he put a small brake pad off a bicicle ( one that has a bolt on it ) through the hole and cured his from folling off forever. I gotta check it out. Hasn't happened to my bike yet but worth remembering.
Old 04-24-2007, 09:48 PM
Grover's Avatar
Grover
Grover is offline
Admin "Kicking The Crap Out Of Spammers"
The part number is 8001 3M Weatherstrip Cement.
You can get is at most andy auto parts house like NAPA of Car Quest.
Many mechnics use it for gasket sealer.
It is great stuff, I have used it for years.
Quick Reply: kick stand rubber stop
