Premium fuel?
Old 04-22-2007, 09:28 PM
pfd161's Avatar
pfd161
pfd161 is offline
Default Premium fuel?
Do I need to run premium fuel in my Ultra? Book says 91 octane?
Thanks !
Dennis
Old 04-22-2007, 09:31 PM
Dalton's Avatar
Dalton
Dalton is offline
Default RE: Premium fuel?
I recommend 93, although the book usually is right. Just a way to prevent pinging in really hot weather.
Do not run anything less, you will get pinging under load.
Old 04-22-2007, 09:32 PM
TowJam's Avatar
TowJam
TowJam is offline
ORIGINAL: pfd161
Yep.
Old 04-22-2007, 09:34 PM
pfd161's Avatar
pfd161
pfd161 is offline
great i got a tank of 87 and I can swear that the bike is backpopping a bit...guess I should have believed the booK!
Love the bike will feed her whatever she needs to PURR!
Old 04-22-2007, 09:35 PM
StreetGlide2006's Avatar
StreetGlide2006
StreetGlide2006 is offline
ORIGINAL: pfd161
Thanks !
Dennis
I not only run premium gas I use the HD fuel additave about every 3rd tank full. Makes me feel better.
Ride Safe,
Mike
Old 04-22-2007, 10:07 PM
smknflms's Avatar
smknflms
smknflms is offline
...Donny Peterson's take on gas..
http://www.heavydutycycles.com/hdgas.htm
Later
Old 04-23-2007, 01:16 AM
brzemo's Avatar
brzemo
brzemo is offline
I have always used premium from a major brand, such as Shell, Mobilor Exxon, etc. I also look for modern stations or ones that take care of their underground tanks. 39 years of biking and counting. Best of luck with your choice.
Old 04-23-2007, 01:24 AM
btefft's Avatar
btefft
btefft is offline
I only use the highest rating at the modern looking stations.
Hack
Old 04-23-2007, 01:26 AM
soos's Avatar
soos
soos is offline
ORIGINAL: pfd161
Thanks !
Dennis
I asked about this last year: https://www.hdforums.com/m_248905/tm.htm
Old 04-23-2007, 01:29 AM
atexn4christ's Avatar
atexn4christ
atexn4christ is offline
I was using Arco in mine cause it was cheap if you can call $3.16 vs. $3.20. I got in the 90's a month ago and noticed that climbing a grade that it was pinging. Since then I have used only Chevron or Shell it should all be that same gas but these stores add chemicals that seem to help. And thats all I have to say about that.
Quick Reply: Premium fuel?
