removing the Ignition Lock Cylinder?
Old 09-13-2005, 01:36 PM
Big Ted's Avatar
Big Ted
Big Ted is offline
Default removing the Ignition Lock Cylinder?
Buddy of mine just picked up his 2006 Road Glide. He is tearing it down to custom paint and asked me if I could find the procedure for removing the ignition lock cylinder on the Road Glides.
Anyone have this information?
Old 09-13-2005, 07:59 PM
screamn_eagle's Avatar
screamn_eagle
screamn_eagle is offline
Default RE: removing the Ignition Lock Cylinder?
i dont have the answer but i bet if you pm tc he will have the answer he knows everything...hehehe...good luck
Old 09-13-2005, 08:02 PM
HDF Tech's Avatar
HDF Tech
HDF Tech is offline
Not absolutely sure on this , but try inserting the key and turn it LEFT fully I think, it opens up a small hole that you depress a tab in it and it releases the cylinder. I'm winging it , but it may work
Old 09-13-2005, 09:25 PM
Big Ted's Avatar
Big Ted
Big Ted is offline
I will pass the information on to him. Thanks.
Old 09-14-2005, 01:04 AM
FLRYDR's Avatar
FLRYDR
FLRYDR is offline
Ted,
I have a copy of the directions for removal on EG models. Not sure if RG ignition is the same or not. Can post if you still haven't figured it out.
FLRYDR
Old 09-14-2005, 01:09 AM
Big Ted's Avatar
Big Ted
Big Ted is offline
Sure. I would appreciate it.
Old 09-14-2005, 01:30 AM
mikeisglidn's Avatar
mikeisglidn
mikeisglidn is offline
i could tell ya....but then id have to kill ya!!
Old 07-30-2007, 04:09 PM
brrujo's Avatar
brrujo
brrujo is offline
3rd Gear
Tell your buddy the best money he will ever spend on his RG is a service manual!!
1. Insert key into switch
2. Turn fully to right (acc)
3. Depress button under switch ****
4. Key will turn further to right.
5. Remove key and switch .
Hope this helps
Old 07-30-2007, 06:10 PM
sewerat's Avatar
sewerat
sewerat is offline
the button he is refering too is a very small almost peice of wire that sticks down, if you use something like a hook dental pick or maybe a very small screwdriver to push it it will be easier. I think i might have used the truck keys to do it with last time but i forget?
William Allan
04-20-2019 11:11 AM
Sp'48'ster
06-25-2012 02:35 PM
hashadenough
04-09-2011 09:45 AM
strtarrow
10-10-2010 05:24 PM
car5car
11-21-2009 08:27 PM
Quick Reply: removing the Ignition Lock Cylinder?
