10 Limited 103 upper engine rattle noise
Old 10-07-2011, 08:44 PM
kdfcogwheel's Avatar
kdfcogwheel
kdfcogwheel is offline
yep, 2000 to 2400 rpm. I just crank the stereo up and it goes away.
Old 10-07-2011, 08:49 PM
TUCCI's Avatar
TUCCI
TUCCI is offline
Originally Posted by blusmbl
Glad somebody else confirmed it. I just picked up an '11 RKC and after riding it all afternoon I noticed a decent amount of valvetrain noise between 2500-3000, and it's louder on decels. Started reading up on it and I guess they all do it. It reminds me of a couple old Mopars I had.
So changing cams moves the rpm around where it makes noise?
Umm I don't notice anything too excessive as far as valve-train noise. It has a small block V8 valve-train sound that's perfectly acceptable to me? I'm really sensitive to that kind of noise after the racket my metric bike had and after that bag of bones this engine is musical.
Old 10-07-2011, 09:01 PM
2black1s's Avatar
2black1s
2black1s is offline
Originally Posted by 1flhtk4me
Mine does the same thing at 2800 rpm.It's either pinging or valvetrain noise.
Ear plugs help alot!
Pinging and Valve Train noise sound nothing like one another.
As far as masking the noise with ear plugs goes; that's great if it's valve train noise - but if it's pinging I want to hear it so I could adjust accordingly, i.e., change speed/gear/rpm as necessary to eliminate, or at least minimize, the ping.
Valve train clatter (within reason) isn't causing any damage. The same cannot be said for pinging.
Old 10-22-2011, 04:53 PM
g money's Avatar
g money
g money is offline
Account Retired
Originally Posted by donf610
Thank you!!
Finally someone else has it at 2800 rpm. I wrote about this when I first got my RG.103. I cant believe I've finally accepted this noise and have gotten use to it. Plus ear plugs do help alot
I am not referring to pinging. I use to have it till I got PC5
My 09 96" was quiet. My 11 103" drives me nuts at 27-2800 rpm. Unreal ticking at that rpm. Dealership says its the "harmonics"
Gary D.
Old 10-22-2011, 10:49 PM
ScreamineagleSERG's Avatar
ScreamineagleSERG
ScreamineagleSERG is offline
Default noises
AIR COOLED= noise... Harmonics along with no cooling fluid to insulate the sound of metal tapping metal is pretty much normal. Piston rattle on the other hand can be the culprit when specific rpm ranges are mentioned. I recently replaced the cylinders and pistons on my 09 110 inch for that reason. Bad from day one, 80 thousandths end gap on the rings from the factory with excessively loose pistons. the cylinders showed no absolutely no wear, just poor parts matching from good old Harley Davidson. The 2800-3000 rpm rattle disappeared for about $700 out of my pocket of course. Not always the reason but very common non the less.
Old 10-28-2011, 10:27 PM
Udawg's Avatar
Udawg
Udawg is offline
Originally Posted by envexed
Ok, just how much upper engine rattle is normal ?
It is a real problem at a certain RPM and goes away close to 3K and under a load in 6th
but in lower gears and just over 2K it bothers me a great deal .
THE ONLY thing I've found that bug me about this Limited.
Any one else have this problem, or do I have a problem?
Mine is EXACTLY as you describe and I do NOT love it.
Old 10-29-2011, 05:04 AM
emwolb's Avatar
emwolb
emwolb is offline
you may not think that 2k rpm's is lugging, but your lifters, rocker arms, etc, are in protest to that statement. drop down a gear and the noise will magically disappear. =problem solved.
Old 10-29-2011, 07:29 AM
Nicky Pass's Avatar
Nicky Pass
Nicky Pass is offline
I think that the 103s don't like anything 2000RPMs. I was out yesterday and when I am above 2000 rpms, it's smooth as can be...decel and being 2000 and under, it vibrated and was a touch noisier. I think it's just like lugging my old Cobra....under a certain rpm.....it would rattle, clank and buck.
Old 06-11-2012, 07:58 PM
Roger Rimshot's Avatar
Roger Rimshot
Roger Rimshot is offline
My 2012 FLHTCU has 6k+ mi on it and I've got the dreaded 'rattle'. It comes and goes and is especially noticeable when cruising @ 70 + in 6th gear. This rattle sounds like the shaker ball in a can of spray paint, and the pattern is random....at first I thought stones were coming off the front tire hitting the fender. This happens when the engine is not under a load, so I doubt its pinging. I've tried 93 octane Shell, Exxon, and cheap gas, and there's no difference.
I've racked my brain trying to imagine what it could be ....its like something in the valve train is "floating out" at certain harmonics.
Because this has been reported by so many 103 owners, I hope we'll eventually find out what's making this racket.
I can accept the noise if I'm convinced no damage is being done to the engine.
Crittenden (01-17-2020)
Old 06-11-2012, 09:02 PM
2black1s's Avatar
2black1s
2black1s is offline
Noise is one of the toughest things there is to diagnose accurately over the internet without experiencing the noise first hand.
In trying to decipher if your noise is a ping or the valve train, some of your descriptions seem to indicate conflicting clues, i.e.;
  • "... It comes and goes and is especially noticeable when cruising @ 70 + in 6th gear. This rattle sounds like the shaker ball in a can of spray paint, and the pattern is random... It comes and goes and is especially noticeable when cruising @ 70 + in 6th gear. This rattle sounds like the shaker ball in a can of spray paint, and the pattern is random"...
This description indicates to me the classic cruise range pinging that many new bikes exhibit.
But then you go on to say;
  • "... This happens when the engine is not under a load, so I doubt its pinging..."
Cruising at 70 mph in 6th gear is a fairly significant load, especially if traveling into a headwind or going up a slight grade, so dismissing the noise from being a ping because the bike isn't under load is not an accurate assessment.
So far, I'd say you have a ping. But this next description says otherwise;
  • "... I've tried 93 octane Shell, Exxon, and cheap gas, and there's no difference..."
When you say cheap gas, do you mean lower octane, or simply an off-brand 93 octane? If changing the octane, the ping should get worse with lower octane and improve with higher. No change would tend to indicate the noise as something other than pinging. Like valve train noise, although valve train noise is typically not so random as you have described, but rather relatively uniform and synchronus with engine RPM.
My best guess based on the information provided is that the noise you describe is pinging. The only thing that could indicate otherwise is your "cheap gas" sentence, although even that is dependent on the answer to my question - lower octane? Or simply an off-brand 93?
Quick Reply: 10 Limited 103 upper engine rattle noise
