Need help with RF PBR300x2
Old 05-01-2012, 11:28 AM
CC Rainman's Avatar
CC Rainman
CC Rainman is offline
Default Need help with RF PBR300x2
I picked up the RF amp and went to install last night. I have a Sony HU with the Hawg wired install kit and Hertz speakers. I was running the Arc and decided to go with a little more power. I read all the threads on the RF. I use the speakers for input instead of the rca like evryone suggested. I soldered the 2 rear speaker outs from the HW converter box to the RF input speaker harness. Put my positive and negative on with no trigger wire. Hooked up the speaker and I had sound for about 5 minutes. Played great then just went dead. Call RF tech and they walked me through a couple of trouble shooting scenarios. THey think the amp is bad. What do you guys think. Everything was working fine with my Arc which I took out. PUZZLED!
Old 05-01-2012, 12:23 PM
murph's Avatar
murph
murph is offline
Amp is probably bad. RF should send you a replacement. I have one and love it. I'm using Polk mm651s. I love the combo.
Old 05-01-2012, 03:47 PM
Harleypingman's Avatar
Harleypingman
Harleypingman is offline
Most folks simply take the wires that were connected to the speakers and use those to connect to the RF input harness; then, use new (or in your case) wires from the output side of the RF as the new speaker wires.
I don't know why you would use anything from HW converter box as an input to the amp since the converter box doesn't carry an audio signal--it simply allows the handlebar controls to control the radio.
Carl
Old 05-01-2012, 05:14 PM
GLACIERPEARL's Avatar
GLACIERPEARL
GLACIERPEARL is offline
In my opinion,......you just downgraded your system. Shoulda stuck with the Arc mini !!
Old 05-01-2012, 05:26 PM
CC Rainman's Avatar
CC Rainman
Well after further investigation. The amp works, I did not have the power wire in far enough and the battery was low. Thanks
Old 05-01-2012, 05:40 PM
GLACIERPEARL
So what's the verdict ?? Which one sounds better ??
Old 05-01-2012, 05:53 PM
CC Rainman's Avatar
CC Rainman
The RF is a lot clearer and a bit louder. Not really that noticible at high speeds but definately notcible at low speed and parked. I was out for about an hour and had no issues. I guess for the money it's worth it.
Old 05-01-2012, 06:17 PM
GLACIERPEARL
Good info for guys that are on the fence !!
Old 05-01-2012, 06:40 PM
CC Rainman's Avatar
CC Rainman
How true. I did the trial and error thing for a while. I tell everyone to go listen to the different products out there. What might be good for you is not for me, that's how I look at things. I think I am finally finished and satified with my stereo.
Herbherb
Audio Systems
05-10-2019 06:21 PM
benson1603
Audio Systems
02-09-2019 01:54 PM
JOW_103
Audio Systems
08-27-2015 12:57 PM
TwoBlue02
Audio Systems
05-11-2014 09:48 AM
b_townchops
Audio Systems
03-19-2014 07:14 PM
Quick Reply: Need help with RF PBR300x2
