"PBR300x2 Installed not impressed at first, now IMPRESSED"
Yeah something is wrong here.......when I installed mine......the difference was crazy....I actually cant turn mine all the way up with out my ear drums bleeding....I dont understand why there is so much trouble on this forums installing this amp...power,ground,and speaker wires......doesnt get much easier than that!!!
2 things
Don't waste your money on new wires to change one size, or a battery if it will start the bike. Read book about how to adjust gain. If it is writen like the book for the 300X4 it is pretty straight forward. OK so 3 things, check to see if the boosted rail or whatever the little light indicator is called is the right color.
already bought a battery. Need a new one anyway. I will change rca's, source unit and battery. We will see.
Also, the 8-ga. wire you now have installed is larger than the 10-ga. you mentioned using instead, which would be moving in the wrong direction. Your power-wire setup isn't your problem unless it is defective, which is doubtful. I'm using 12-ga. power wire, which is below spec but rated for 28A, and have no problems with overheating or anything else. Anyway, there's no way this system is going to pull that much current the way I use it.
As for setting gain, there is an **** way of doing that with a multimeter, which I did at first but then tweaked it by ear. With HU volume at half-way up the scale I set gain for a comfortable listening level at highway speeds. This has worked for me and it isn't rocket science, as the gain settings are little more than volume controls. Note that as gain is set higher the rate of volume increase also goes up.
Maybe I'm reading something wrong, but if you wrote this correctly, and your filter is set to HP, then that is your problem, it should be set to AP, which is in the center.
Wires, battery and light indicator. I guess if ya needed a battery then by all means replace it. And for sure what iclick says about wire gauge, bigger than what is required certainly wont hurt. And if it is set to HP you will for the most part get tweeter only type of noise. I did that the first time and was very let down, swithed to AP or all pass and was blown away. Would be great if that is all ya gotta do to fix it.
