RF amp wiring, need help
Old 02-26-2012, 03:41 AM
pit1600's Avatar
pit1600
pit1600 is offline
Default RF amp wiring, need help
I'm mounting my winter project, an RF amp with 6,5" speakers in fairing and lowers. I'm using a Pioneer head unit.
My question is how do i wire all this stuff for running 4 speakers in front and 2 in TP?
I will use RCA for the amp but 1 or 2 RCA set (got 3 on HU)?
could i use rear speaker wire direct from HU to connect my TP speakers?
Please help me to enjoy my new amp.
Old 02-26-2012, 05:34 AM
VTL nut's Avatar
VTL nut
VTL nut is offline
You could run the front 4 speakers in series (2 per channel).
Running them in parallel will cut the impedence down next to nothing, and may cause issues for the amp.
Running the tour pak speaks from the head unit, and the 4 fronts from the line level (RCA) to external amp should work fine (if your HU allows this configuration).
Depending on speaker impedence and amp load capability (check documentation) should determine series or parallel configuring the front speaks.
Post model #'s of amp and head unit and we can draw a picture with your speaker set up.
Old 02-26-2012, 06:29 AM
bigdumbnoitall00's Avatar
bigdumbnoitall00
bigdumbnoitall00 is offline
the amp is 4 ohm only,best to run 4 speakers from the amp,u can run 2 per channel in series,but then half the power to each speaker,I've found it sounds better with one per channel.
Old 02-26-2012, 06:45 AM
davidw221's Avatar
davidw221
davidw221 is offline
My bike is down doing upgrades at a buddies home shop, next to mine is a SG upgrade, this guy has the new speakers in the lids, awsome!
He has a RF for the fairing speakers, and the lower fairing speakers, which leaves out the lid speakers for using the amp.
He purchased a second RF amp and is installing it to run the rear lid speakers, I can't wait to see how this one is going to workout?
Man, did I mention this SG is Awsome!
Old 02-26-2012, 07:25 AM
pit1600's Avatar
pit1600
pit1600 is offline
I've got RF PBR300x4 amp and RF speakers, same set as sold by Bagger Nation. My problem is that i have 3 line level in head unit (Pioneer DEH P7000UB), one front, one rear and one for sub.
I connected my speakers (fairing and lowers) to output of the amp. Do i have to connect 2 RCA (front and rear) or only 1?
I will use normal rear output of the head unit for speaker pods in TP.
Is it good?
shaneballance
Audio Systems
15
08-13-2018 03:51 PM
TO34
Audio Systems
07-12-2015 07:11 PM
2007z71
Audio Systems
03-29-2015 10:53 AM
reserve
07-27-2012 11:13 AM
ImaNewbie
Audio Systems
05-17-2012 05:56 AM
Quick Reply: RF amp wiring, need help
