2nd fried Rf 300x4!!
Old 04-20-2012, 07:52 PM
2black1s's Avatar
2black1s
2black1s is offline
Originally Posted by dbell66253
Either you have really bad luck, or somethings not wired right, judging by the buzzing sound, I'd say somethings not right. The amp should not be grounded to the battery, find a spot on the frame (the front gas tank mount is usually good) scrape the paint, make sure you have a good ground. Also just out of curiousity your spreakers aren't grounded are they, or none of the output wires from the amp or head unit?
Why not?
The battery is as good a ground as any. When you ground something to the frame, the frame is simply a part of the circuit connected to the battery to create the ground.
Anything that is grounded to the frame could alternately be grounded to the battery and will function properly.
Old 04-20-2012, 08:07 PM
dbell66253's Avatar
dbell66253
dbell66253 is offline
Originally Posted by 2black1s
Why not?
You want your ground wire to be as short as possible, limit the amount of interference.
Old 04-20-2012, 09:18 PM
klu408's Avatar
klu408
klu408 is offline
The thing that gets me is I have ran 2 other amps with same wiring and everything and they were fine....
And both of the RF amps played fine until all of a sudden they started buzzing through the speakers.
speakers aren't grounded I actually rerun all my wiring today before installing the 2nd RF amp just to make sure. But it played for about 35 seconds and started buzzing... I hadn't even touched gains or anything yet. And amp wasn't hot or anything.
Cowboyblm
11-10-2017 04:46 AM
scarin
Audio Systems
02-17-2014 10:10 AM
DoubleZ
03-25-2011 07:20 PM
destack
05-14-2008 07:00 PM
woodhaven glide
08-02-2007 06:39 PM
Quick Reply: 2nd fried Rf 300x4!!
