RF PBR amp and speakers installed,very dissapointed
Old 02-23-2012, 07:18 PM
Cowboy Rob's Avatar
Cowboy Rob
Cowboy Rob is offline
Big Kahuna HDF Member
Received 2,565 Likes on 1,497 Posts
Unhappy RF PBR amp and speakers installed,very dissapointed
I installed the PBR 300x4 with the RF 5 1/4 in the tp. Up front I went with Titan/Hertz 6 1/2. I have amp set up for all pass,gain set first at 3 then 4,now finally at 5. I have to say I expected a lot more. It is pretty clear but to hear it really good you have to turn it almost all the way up. Put it this way with the HK radio my volume bar is under the E in volume. I can actually hear the rear speakers from the tp pods a lot more. I don't think anything is installed wrong,just wondering if there might be something I'am missing.
Old 02-23-2012, 08:04 PM
wjl24's Avatar
wjl24
wjl24 is offline
Sorry to hear that. I've been giving some thought to a similar set up. I held off when I found out that the Titans are 3 ohms. The Rockfords are 4. I don't know if that is part of the problem or not. I was told (by RF tech) anything under 4 ohms would make that amp run hot and those run hot anyway.
Hopefully someone here can help you out. Good luck.
Old 02-23-2012, 08:05 PM
ICIBUY's Avatar
ICIBUY
ICIBUY is offline
Did you wire these in series using all 4 channels? I dont want to talk like you dont know what you are doing by any means so dont take that wrong. I just seen that the front and rear channels have separate gain controls as well... I'm sure you adjusted both gains as well?
Old 02-23-2012, 08:10 PM
Cowboy Rob's Avatar
Cowboy Rob
Yes both gains are adjusted,and all 4 channels are being used. These new Biketronics Titan/Hertz 2's,or what ever the hell they call them are 4ohm. The older ones were 3ohm.
Old 02-23-2012, 08:51 PM
leohd's Avatar
leohd
leohd is offline
go ask your buddy art vandelay
Old 02-23-2012, 08:53 PM
redrubicon2004's Avatar
redrubicon2004
redrubicon2004 is offline
I have the same setup on mine only I have polk audio 6x9's in the rear. Mine sounds pretty good to me.....Day and night different from the stock setup!
Old 02-23-2012, 09:20 PM
ICIBUY's Avatar
ICIBUY
ICIBUY is offline
Sounds like you have everything correct... bummer! Too bad that amp isnt 2ohm stable you could get a little more out of it but I have heard they already run hot so that probably wouldnt be a option anyway. On the bright side at least they are fairly cheap
Old 02-23-2012, 09:49 PM
1931jamesw's Avatar
1931jamesw
1931jamesw is offline
My limited experience with audio on HD's is that bang for the buck, a simple speaker change and no amp is best. If you want to run a amp, the Hawg Wired systems are best. Again, this is just my experience. I think once you get out on the highway at 70 mph, that is where you will see the benefits of your upgrades.
Old 02-23-2012, 10:54 PM
piesik650's Avatar
piesik650
piesik650 is offline
hawg wired is they way to go.
Old 02-23-2012, 11:59 PM
dbell66253's Avatar
dbell66253
dbell66253 is offline
What is the sensitivity rating on the Hertz speakers compared to the RFs? There is no way you should be getting more sound from the 5-1/4 than the 6-1/2s unless the 6-1/2s are an inferior speaker. Also are you using any kind of dampening material to help with the acoustics.
Quick Reply: RF PBR amp and speakers installed,very dissapointed
