Go Back   Harley Davidson Forums > General Harley Davidson Forums > General Harley Davidson Chat
Sign in using an external account
Register Forgot Password?
Search
Notices
Sponsored by: J&P Cycles
Welcome to HDForums.com!
Thread Tools Search this Thread
Old 03-26-2008, 01:21 PM
Pitts2112 Pitts2112 is offline
Default RE: Fork corrosion on '06 Sportster
Quote:
ORIGINAL: whaap
When you have two different metals in contact with each other and then ad water (especially salt water) you set up a condition called electrolysis. The softer (sacrificial) metal will deteriorate quite rapidly.
Of course. I hadn't thought of that. Good point. Thanks, Whaap. Most helpful answer to date!
Old 03-26-2008, 03:48 PM
3power 3power is offline
I would take it to the dealer and see what you can work out as a warranty fix.
Old 03-26-2008, 04:06 PM
Quote:
ORIGINAL: 3power
3P,
That's why I originally asked the question, to see if this was a common warranty item. I already have to take it in to have the second replacement on the rear wheel due to peeling chrome, so I think I'll have them take a look at this issue as well. I just wanted to get an idea on where I stood on it.
Cheers!
Old 03-26-2008, 06:38 PM
seniorsuperglideE8 seniorsuperglideE8 is offline
Pitts, that's classic dis-similar corrosion, salt and water moisture did it. Don't want to kick you while you down but a lot of seasoned riders avoid riding in the winter because of that particular reason. You should see how fast magnesium will corrode. Myself I use Starbrite Marine Polish on most every surface except paint on my two bikes. It's a good sealer and won't "burn" off like some of the other waxes. Look for it a marine store like West Marine. To repair, some fork dis-assembly may be required. Good luck.
__________________
tailhook seat plumber
02 FXD 95" BB, 203 cams, low restriction mufflers
05 FXDLI, stage 1, low restriction mufflers ( on Craig's list)
13 Road Glide Ultra, getting some bling...
"Memo to White House, tell the truth, less memorization involved."
Old 03-26-2008, 08:15 PM
Chopperz's Avatar
Chopperz Chopperz is offline
I have over 14,000 miles on my 07 Got it in Nov. 06 ride it in all kinds of salt,but i do rinse the shlt out of it,afterwards.Anyways,I have no such corrosion taking place.
[IMG]local://upfiles/42833/BF4A976C594D486186B7BBABF58057A7.jpg[/IMG]
__________________
VF-11 Red Ripper
Old 03-27-2008, 01:25 PM
Default RE: Fork corrosion on '06 Sportster - UPDATE
Well, I took the Sporty down to the dealer in Southampton, Dockgate 20, and they're going to cover the fork lowers under warranty. Ben, the tech, said it's pretty common over here where the winters are really wet and the roads salty. He's going to do the rear wheel (peeling chrome), too. Good dude, overall. Very pragmatic view of what should and shouldn't be covered. Doesn't take the **** and, likewise, won't let the **** be taken, either.
Oh, and to give you an indicator of what the weather's been like over here for the last 6 months or so, when I started getting ready to get the bike out, the skies were blue and sunny. By the time I got the bike out, showers had developed. [:@] Drove through two more on the way. [:@][:@]
And, you know what? Hail sounds really cool when it hits your helmet at 70 mph!!
And, by the time I left the dealer, the clouds had cleared and it was warm(er) and beautifully sunny. And I had the rest of the afternoon free. Guess what I did!!
Old 03-27-2008, 02:59 PM
BCguy's Avatar
BCguy BCguy is offline
Glad to hear that your dealer is going to make it right. Sounds like a good guy.
__________________
2008 Crimson Red FLTR, ABS, V&H Ovals, SE a/c, Cee Bailey's, HoggChopps
Pro libertate
Tags
06, 2007, corroded, corrosion, covered, davidson, fork, forks, front, guards, harley, motorcycle, polish, repair, sportster, vrsca, warranty
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Sponsors
Internet Brands, Inc.
