Seat question
That pad is WAY thick. You could have it reworked by someone like mean city cycles and replace that thick foam with some gel or memory foam, That way, you might could shave an inch or two off while still keeping the comfort.
FYI, they are a sponsor here, or at least were. So there may be a member discount available.
Received 19,827 Likes
Saddleman wasn’t mentioned.
See if she feels like the space it provides (without the pad) is enough, then look into options that push the sissy bar back by that much.
That would allow you to reinstall the pad and give her the space she needs.
I suspect that the mounting arms on the sissy bar are either replaceable with longer versions, or yours could be customized for the additional space.
